Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
iPhone overheat and won't turn on
A customer brought me his iPhone 7 plus he said he was using it and turned off and it was hot
I tested a new battery and screen what I notice is when I use the new battery it starts to overheat and won't turn on
Any ideas?
Bu iyi bir soru mu?
Puan 0
1 Yorum
sound like liquid damage
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the phone is getting abnormally warm, then something inside is causing an excessive current draw (hence heat). This will be due to a failed or partially failed component, be it modular or board level.
One thing you could try is to disconnect everything except the lightning port and battery (always disconnect the battery first though) and then connect the phone to an iTunes enabled computer. If it doesn’t boot or get recognized, then you most likely have a logic board issue, which would require a micro-soldering repair.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Is there a way to do this without having to take the phone apart?
Right now I don't have the tools to do this, and all the stores are closed due to the recent quarantine, and honestly, I don't want to mess up my phone by opening it up, because I don't know what I'm doing.
tarafından
Yorum Ekle
I got an IPhone 7 and it got wet so i tried to take off the screen , but when that happen the phone just started getting extremely hot so i just put the screen back together, and then the screen wouldn’t turn on, so i let it cool down and it still dont turn. So i need help with that.
Puan 2
1 Yorum:
Even when i hooked up the charger it heated up again and i just dont know what to do
tarafından
Yorum Ekle
I replaced my Iphone 7 plus Battery. The battery brand is 'Aspor' so faithful. And health is 100%.
But after replace the battery CPU gets hot and hot and discharge quickly.
Technician said phone shorted.
  • What I can do now?
Puan 0
Yorum Ekle
iPhones 7 Plus or any other iPhone overheating did not cause any problems until iOS 14.6 was installed, so it looks like a software or app glitch. Once Apple releases an update, the issue will be fixed.
Puan 0
Yorum Ekle
Yanıtını ekle
armandomh91 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 6,080
