Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
I have no headlights... please help
I recently bought a used 2006 altima and the low beam headlights will not turn on. ALL the other parking lights and tail lights work as well as the high beams. I replaced the low beam bulbs, I checked the 2 fuses under the hood, I bought a new headlight switch on the steering column and replaced that. Still no low beams!! What am I missing? Someone please help.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hey! Everybody! I found one solution for no low beams on my 02 altima. It cost me too! Make sure the bulbs are clamped back into place. The clamps are actually the ground for the headlights.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Steve Boylan first here is how they operate.
Low Beam Operation
With the lighting switch in 2ND position, the BCM receives input requesting the headlamps to illuminate. This
input is communicated to the IPDM E/R across the CAN communication lines. The CPU of the IPDM E/R controls
the headlamp low relay coil. When energized, this relay directs power
  • through 15A fuse (No. 36, located in the IPDM E/R)
  • through IPDM E/R terminal 20
  • to headlamp RH terminal 1, and
  • through 15A fuse (No. 45, located in the IPDM E/R)
  • through IPDM E/R terminal 30
  • to headlamp LH terminal 1.
  • Ground is supplied
  • to headlamp RH terminal 2
  • to headlamp LH terminal 2
  • through grounds E15 and E24.
With power and ground supplied, low beam headlamps illuminate.
“I checked the 2 fuses under the hood, I bought a new headlight switch on the steering column and replaced that “, but you did not say you checked the relay. That is where I would start.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The, turn signal does work?
tarafından
Yorum Ekle
When I first googled this…I found that there was a factory defect
Puan 0
Yorum Ekle
Yanıtını ekle
Steve Boylan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 15,366
