Making custom THIN, SSD, 20k song capacity Gen 5.5 iPod?
Hello,
I’d like a Gen 5.5 (enhanced) iPod Classic/Video. I have a 6th gen, and know it sounds bad compared to my original 4th gen. That said, the 6th gen is a bit thinner than the thick 5th gen versions. Sadly, you have to get the thick version to get a higher song capacity (20k instead of the 7.5k you can have on the thin 30gb version).
So, can I get a thick 80gb 5th gen enhanced, change the HDD for the SSD adapter, get a thin back plate and battery, and be good to go?
Bu iyi bir soru mu?
2 Yorum
@lingenfr I ended up %#*@ near destroying my gen 6 getting it apart. After that, I found a custom ipod assembler on ebay. He made the ipod to my wants and replaced everything I manged and replaced the wear parts on my gen 6.
The custom ipod ended up being a gen 5.5 unit with the popular SSD unit. Using that SSD unit in place of the HDD actually left enough extra room for the '80 hour' battery mod. It lasts a LONG time, and just requires a cheap larger battery and removing some material off the frame, or as I understand it. Again, keep in mind it still was able to be the thin back cover.
IIRC, thin are shaped for the bevel on the thin back case/cover/housing/plate. Research and/or talking to the ipod assembler, it WOULD work, but he didn't want to put in an improper one. This was before I ended up with a whole new ipod built.
Any comms assistance was always appreciated. They weren't simple, at least not some of the truck systems.
CavScout tarafından
Unless I missed something, the answer didn't really provide an answer. Trying to avoid the trial and error of "make sure it is deep enough".
I want to do the same thing, was the thin back deep enough to accommodate the iFlash/SSD or not?
Not a Cav Scout, but I've provided communications for many.
Also, did you have to change out the headphone jack/hold switch? If so, what did you use? Thanks.
Thanks.
Rusty Lingenfelter tarafından
