Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Mower will not start with key
Problems started with a motor choking with excessive gas ( removed and cleaned carb).did not cure the problem. Started the mower again and let it run at 1/3 speed and ran normally. Engaged the mower deck and choking started right away and then stopped.
After dis- engaging the deck I tried to start the mower with the key switch and it would not . Leaving the key on ,I was able to start the motor by jumping the solinode. Still choking at medium to high speed and now no deck engagement when I put up the knob on the dashboard. Also noted at this time that the running hours meter also was not working.
Would the seat safety switch cause all of this? Or the key switch?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
shavorhead  all of this sounds like the key switch. It appears as if it does not close all circuits. I’d start with a replacement. If nothing else it will provide you with a know-good starting point for further troubleshooting. Also, give us the exact model number for your mower
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
shavorhead sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 76
