Ana içeriğe geç
Guides for gas and electric stove, range, and oven repair.
Thor / Hallman / Hyxion range clicking
I have a Hallman range (same as Thor, both made by Hyxion) Model HRG3609, serial HRG3609U00224 that clicks whenever I put it on HIGH and place a large pot or pan over the burner. This has been the case since the first day I uncrated it. I have cleaned the burners thoroughly and dried them. I have checked to make sure all of the holes are free of debris.
The manufacturer tells me this is a common problem but they are unable to help me resolve it and nobody in my area will work on this brand of range (I’m in Atlanta, so the pool is pretty deep and nobody will touch it).
There are photos and videos at this link
Thanks in advance for your help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
Did you find a solution? I have the same problem with the only the strongest burner…
tarafından
Same stove. Same problem
tarafından
Samantha my answer has not changed. I see Brandon many have found d the answer.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Look at ALL the photos in this album:
https://photos.app.goo.gl/82VrTKW9encPow...
Read the document here:
https://drive.google.com/file/d/1qLkIvlb...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Thanks for the phone call and posting this.
She certainly is a beauty. Are you sure you want to cook on her?
Is the problem with just one burner?
I found a source for parts here:
http://marinrestaurantsupply.com/index.p...
Cause 1
Spark Ignition Switch
One of the spark ignition switches might be defective. The spark ignition switch sends voltage to the spark module. When the electrical contacts inside the switch close, power flows to the spark module. If the spark ignition switch fails with the electrical contacts closed, the switch will send continuous voltage to the spark module. To determine if any of the spark ignition switches is defective, use a multimeter to test each of the switches for continuity. If a spark ignition switches shows continuity at all settings, replace it.
Cause 2
Spark Ignition Switch and Harness
One of the spark ignition switches might be defective. The spark ignition switch sends voltage to the spark module. When the electrical contacts inside the switch close, power flows to the spark module. If the switch contacts are wet or stuck in a closed position, the switch will send continuous voltage to the spark module, no matter where the dial is set. Each of the switches can be tested individually to determine if they are shorted. If a spark ignition switch is shorted and is not wet, or if drying it out doesn’t solve the problem, replace the switch.
Parts
Cause 3
Spark Module
The spark module provides power to each surface burner spark electrode. If the spark module fails, it may cause the burners to spark continuously. However, the spark ignition switch is more likely to be at fault. Before replacing the spark module, first test the spark ignition switch. If the spark ignition switch is working properly, consider replacing the spark module.
Puan 0
Yorum Ekle
Yanıtını ekle
Brandon Clifton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 2,766
