Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Soru Tümünü görüntüle
MacBook Pro A1398, 820-3332A Logic Board TSOP Error
Hello,
I have a 2013 Macbook Pro 15. 10 seconds into the bootup the fans go full throttle, the MacBook is slow to boot, and once it does manage to boot the CPU is > 100% at all times.
  • Ran AHT, it reported – 4SNS/1/40000000 TsOP—124
  • Bought a new trackpad with cable, replaced. No change, same issue.
  • Removed the logic board, cleaned everything and reinstalled. No change, same issue.
Any suggestions / help would be deeply appreciated. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Check the logic board thoroughly for damage; blown components or damaged sensor circuits can cause this issue. Test it will just the charging port, fans, SSD and trackpad connected; if the fans still go full speed it will be logic board related.
If it is logic board related, I would suggest taking it to a repair centre to check out; a decent repairer will know areas to check and will determine what is causing the fault.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mandeep Singh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 192
