Ana içeriğe geç
Samsung I9000 Galaxy S olarak da bilinen A 3G veya Çin piyasasında Samsung I9008 Galaxy S olarak bilinen akıllı telefon, 2010 baharında piyasaya sürüldü.
Does the last letter in the part number matter?
I ordered a charging port replacement for a S5 and the part model on the board itself says SM-G900W and I got a SM-G900T. I installed the part and the charging port works now but the microphone doesn’t during calls (except on speakerphone, which uses the secondary microphone). I am not sure what the issue may be as the only difference between the parts seems to be the last letter.
Any repair shops out there able to explain if the last letter on the part number matters or how do you determine which part is the right one.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
yes it does and it doesn’t
you only need to use the shell from the SM-G900W to install the SM-G900T
that will correct the circuit
same situation when using an iPhone 6s ear piece unit for an iPhone 6 it will fit in but won’t work unless the bracket from 6 is use to install the 6s on the 6
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
So the part will work. It fits and looks the same as the original one other then the lettering printed on it.
tarafından
exactly
the difference are mostly changes in the shell design because of the difference in architecture build of the actual phone models
tarafından
Yorum Ekle
Yanıtını ekle
TMS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 470
