Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Soru Tümünü görüntüle
MacBook Pro 15 2013 Integrated GPU goes sleep itself randomly
Hi there :)
Things what I know and what I did with this MacBook:
  • I’ve done SMC and PRAM reset - no changes
  • fresh installation latest 10.13.6 High Sierra - no other apps installed
  • no magnetic field around
  • Apple said their diagnostic tool says MacBook is in fully working condition :/
  • to be more weird - I’ve got MacBook Pro 13 2015 and it has problem with wake up after more than 12hrs sleep and it wakes up after about 1-2 minutes everytime - it wakes up instantly if left for about 30 minutes - when left for sleep or even off over night - it will not wake up / won’t on for about 1-2 minutes.
I start to suspect Apple is messing up with all those FIRMWARE updates in High Sierra - there were about 3 of them!
But I am not sure if it is a problem - but - why Apple says MacBook is 100% in fully working condition?
Update (08/22/2018)
Here are some additional info: when MacBook goes to sleep - when I press power button very short - it is switching on “from beginning” - it is like it is not going to sleep - but switch off itself
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
You stated you did a fresh install of MacOS High Sierra (10.13.6) did you wipe the drive before you installed so nothing was on the partition?
When you say the system goes to sleep randomly was the lid up or did you have it down and using an external monitor?
The magnetic field is only an issue if you put it close to the Hall lid sensor otherwise you could be in a MRI and that wont effect your system ;-}
Diagnostics has its limits! It only tests the inner world of the computer not the outer world like displays and other analog inputs/outputs.
The firmware updates are mostly for malware protection signatures for XProtect which is a good thing! XProtect Explained: How Your Mac’s Built-in Anti-malware Software Works
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would say that you may have a battery issue. Possibly also a “hall sensor” failure.
Start by testing the battery, download and install “coconutbattery” and post the results here.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I added info below - thank You
tarafından
Yorum Ekle
The issue occurs when you left your charger connected to the Mac and SMC itself detected your battery status accordingly to get into sleep mode several times, first try to reset SMC and rotate some cycles to full charge then complete discharge repeat this step several times make sure once charged completely you have to remove the charger.
Puan 0
1 Yorum:
ok - I am doing first full battery cycle - it has pretty high 770 cycles - soon will find out if it is happening on charger or on battery
tarafından
Yorum Ekle
Assuming your battery is in good shape your issue maybe merely the energy & screen settings of your system.
Lets review Mac’s Sleep & Hibernation options as you might not be using the best settings for your system. Keep in mind a HDD system will be slower in waking than a SSD based system and the age of the system will also have different behaviors as Apple has updated how it works on different series.
For starters Linus offers a good overview: Should you Hibernate, Shut down, or put your PC to sleep?
Here’s a good overview of the different modes: Mac Sleep Settings for Performance and Battery Life
And don’t forget your systems settings are accessible by clicking on the battery icon. And your Desktop & Screensaver settings are in the Preferences.
Puan 0
Yorum Ekle
Yanıtını ekle
Bart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 909
