Ana içeriğe geç
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
What do I check next? Kenmore washer 110.21102012
Kenmore Washer 110.21102012
I have replaced the lid lock switch, striker, control board and actuator in that order.
I have recalibrated it. I did both manual and automatic mode test to which it passed both.
Washer will start a cycle, fill with water, agitate 5-15 minutes and then shuts off completely. It’s getting power. No circuits are tripped. No wires are loose or corroded. I don’t know what to check next.
Somebody please help and point me in the right direction.
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@singlemom
since you already replaced the most common items on this washer, check the motor. It may have a bad start capacitor etc. Also make sure that your outlet is working properly. Consider plugging the washer into adifferent outlet and see if that changes anything.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Ronica sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 161
