Ana içeriğe geç
22 Eylül 2017'de piyasaya sürüldü. Model A1864, A1897. GSM veya CDMA, 64 veya 256 GB depolama seçenekleri mevcut olup renk seçenekleri altın, gümüş ve uzay grisi şeklindedir.
iPhone 8 Plus Backlight/Black Shadow Problem
Hey!
My iPhone 8 Plus has a black shadow on the right bottom corner of the screen after I changed the LCD Screen. Could this be a bad Backlight IC? If yes where is the Backlight IC on the motherboard and would changing it fix the problem like it does on the other iPhones. Couldn’t find anything on the internet for the 8 plus regarding the issue I have.
Thanks,
Fahad
Update (08/27/2018)
I checked the motherboard and turns out the pin 45 was bad on the J5700 connector. So I flipped the board to check the fiter/fuse and the small C5733 is bad. What do I replace it with?
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The shadow is because you have one of the two strips of LEDs that make up the backlight not working, and it is usually not working because it has an open line in this scenario. You create an open line on the backlight circuit either through damaging a pin at the connector, or connecting a screen without first disconnecting the battery which can blow the backlight filter, or if you have a water damaged induced short (or spontaneously occuring) on one of the two backlight circuits.
You’ve already ruled out bad screen which was another possibility, so you know this is a logic board repair. You can either buy all the equipment and learn how to do microsoldering and board level troubleshooting (iPhone 8p backlight is not bad for a beginner project), find a local microsolderer or use a mail-in logic board repair service.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Yep the lower right backlight strip is probably not working. Where is the BL IC/Filter on the Motherboard since I can’t find it online.
tarafından
Look it up on the schematic. If you need help, then tell us what you are thinking as you look at the schematic and we will let you know if you're on the right track. Start at the connector and try to figure it out.
Step one is to figure out if you have a short or open on the backlight anode and cathode lines for either backlight circuit on the 8 plus.
tarafından
Yorum Ekle
theres a chip on the lcd flex in the lower right area, it maybe isnt aligned properly and causing it to push on the lcd
Puan 1
3 Yorum:
Nope, Installed the old LCD back and same issue. Lower right has a black shadow.
tarafından
did you try the screen without clipping it in to see if the shadow is still there
tarafından
Yes it was there when out too.
tarafından
Yorum Ekle
Is the backlight coil is a long ic located next to the charging port conector. Put pressure on it and see if the black shadow goes away.
Puan 1
Yorum Ekle
just replace it the U5600 ic problem slove
Puan 1
Yorum Ekle
not working this
Puan 0
Yorum Ekle
Yanıtını ekle
Fahad Zareef Khan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 38
Son 30 gün: 53
Her zaman: 11,381
