Ana içeriğe geç
2009 yılında piyasaya sürülen giriş seviyesi Photosmart yazıcı. Tek kullanımlık baskı kafasına sahip HP Üç Renkli mürekkep kartuşları kullanır.
Scan Failure on second attempt.
I can print one copy after I turn the printer on. A second attemp will give me a “Scan Failure”. I restart the printer and the same thing happens. If I try to Scan, I get the overview ok but The scan failure comes up if I try to scan. I looks like the scanner is not returning to the idle position after a first scan.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like your reading head for your scanner is not returning to it’s “home” position. If you are halfway not fumble-fingered like me, you can gin entry by usually removing the top glass. You should be able to get the head into it’s '‘home” position and check the cogged belt that moves it to determine if the belt just jumped a notch or if you have worn belt or stepper-motor problems. Check for a mark on the belt made by a marker at the factory when your unit was first set up. This will help you determine what’s going on. If it checks out mechanically, try reloading your driver software for the HP. And be careful around any of the printer’s so-called “secure” home pages for software downloading—-they seem to be a heavily targeted area for con artists with their own software and programs.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jnmstuff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 314
