Ana içeriğe geç
Keurig K55, model numarası olan K55 Classic Series ile tanımlanabilir. 2 Aralık 2015 tarihinde piyasaya sürülen K55, hem K-Cup kapsülleri hem de geleneksel öğütülmüş kahveyi destekler.
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
tarafından
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
tarafından
Sure will do when I get home from work. Thanks for ur help
tarafından
Hi please find a picture below.
tarafından
Does anyone which power supply I have to buy as in model number etc...
Thanks
tarafından
Yorum Ekle
Resim
here is the picture
Puan 0
Yorum Ekle
Yanıtını ekle
Vishal Patel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 1,138
