Ana içeriğe geç
Bu eksiksiz ev sinema sistemi; çoklu açı ve yakınlaştırma işlevlerine sahip, aşamalı taramalı beş diskli DVD değiştiricili ince tasarımlı gümüş bir DVD alıcısı, 720 watt'lık bir amplifikatör ve dahili Dolby Digital/DTS/Dolby Pro Logic II özelliklerini içerir. Ayrıca beş adet uyumlu gümüş renkli tam aralıklı uydu hoparlörü ve 120 watt'lık bir subwoofer içerir.
won't stay powered on
this system has been in storage for 12 years. i powered it up today. the red stand by light comes on, indicating system not on. when i press any of the disc or am/fm buttons, the display lights up indicating system on, but the goes back to system off mode in a few seconds. something i’m missing?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
@sarah_rver is your system a JVC TH-M303?
tarafından
yes it is. had it for 13 years
tarafından
@sarah_rver just to clarify, it turns on but after a few minutes it turns off. Any LED lights on or any sign of life when it turns off?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Neither the user nor service manuals provide any particular clues based upon what you have described. Therefore, I must start with the typical failure. Disconnect the speakers and try again. I expect that the unit will power up normally.
You can reference the service manual here: http://www.go-gddq.com/upload/2010-02/10...
The main power amp resides inside the subwoofer. Check to see if there is a protect light on the subwoofer.
If there is a light or the unit only “works” with the subwoofer disconnected, I would suspect that one of the amp chips inside the subwoofer is defective and further investigation is required. There are 2 large black amp-packs inside the subwoofer (STK413-400 and STK413-=430). One or both of these may be defective.
Try removing the speaker connections and report the results here.
Dan
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Sarah Hughes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,319
