Ana içeriğe geç
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
power loss when accelerating
I need help I have a Ford Mustang GT 2004 and the problem I get is when I step on the car does not react aggressively and begins to pull speeches but at 2000 revolutions takes off is a period of time in which the engine dies. I already change coiles, new spark plugs, filter zagolina, service to the injectors and remains the same as any recommendation would be quite grateful
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check your compression . Any drop in compression will hurt the performance. Is you car losing coolant? Is it casting any codes ? If so what ? Was there any misfires before you changed out the plugs and coils . If so you may be dealing with back-pressure from the catalytic converter. Raw fuel in the converter can cause it to plug and a plugged converter kills power . Also do you have an aftermarket tune on the car . Change out the air filter as well so it can breath Just a few things to look at . Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
it acts like tractioin control it takes off better if I turn it off
tarafından
So what’s the problem? What exactly do I need to fix if I changed my spark plugs and nothing changed oil changed. After market pipes caused my Cadillac was clogged
tarafından
Yorum Ekle
Yanıtını ekle
José saracho sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 3,270
