Ana içeriğe geç
Repair information for the Asus VivoBook S551LB laptop. First available on Amazon in July of 2013. Model number: V551LB-DB71T.
Asus S551LN is totally dead. Tracing the failure?
Ok, her’s the problem. The laptop Asus S551LN doesn’t power up, completely dead. The adapter gives 19 volts as it should. Of course I have tried to remove all the connected hardware and start without any luck. I have tried holding the power button as well.
I don’t seem to find any schematics on this except some pictures of the motherboard. So I measured the continuity at the power on switch. As drawn in the image I get continuity on adjacent legs and I get continuity on opposite legs when switch is pressed. (I assume the switch is working).
There is this 3 leg mosfet (i think so) next to the powerjack. How to check if it is functioning as it should?
I couldn’t identify any power IC or diode that could be a reason for this.
Any help here?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Bonjour, j'ai le même problème, c'était l'un des 2 moffset (8 pins) en haut a droite de l'avant dernière photo du post. Il faut remplacer celui qui est en continuité avec un testeur. Voir video exemple :
https://youtu.be/QvGP2N8_Vb8
Bonne chance
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It could be the CMOS battery.
Right next to the ram shroud.
I was given an a551ln cause it “faulty”
Charge light on but no screen.
There's steps online how to reset the CMOS.
Hope that helps…in 2022
Puan 0
Yorum Ekle
Yanıtını ekle
Paulius sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 776
