Ana içeriğe geç
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
roku keeps shutting off
why does my roku 3 keep shutting down?
Update (09/10/2018)
Thanks but I did. Tried different HDMI as well as the three RCA jacks and also 2 different tv’s. I also reset the Roku to factory settings and even then, it shut down while loading all the channels. As I was re-setting it up it accepted the wireless name/password and started to load 1 of 88 channels but shut down while the channels were loading. I unplugged and plugged back in and it started loading 1 of 52 channels then shut down again midstream. Re-booted again and loading 1 of 33… shut down a couple more times but finally completed. After ALL that back to the same thing. after 2 to 5 minutes of watching whatever it shuts down.
Bu iyi bir soru mu?
Puan 2
8 Yorum
Frustrated had enough can get relief from my Roku shutting down every 5-10 minutes and going back to the home screen. Tried everything recommended. I did a hard reset where I had to enter everything again. This started 3 months a go. Nothing changed in my home. No new additions added electronically. No matter what I watch it goes back to home screen. I called my I .T provider everything is up to par. I called Amazon prime everything checked out. Changed HDMI cables and cleaned the metal ends with alcohol. Unplugged the Roku device,reset my router,etc. I'm at a loss what to do next.i did a hard reboot with Roku. Can't talk to Roku tech support. This is a growing problem. In my opinion it just might be a hardware problem it software problem because do many people are having issues with a variety of streaming devices according to the posts provided. How do we get professional help from Roku? I feel that they don't take this matter seriously. Just venting exasperated.
tarafından
I too have had troubles recently. It cuts off mid stream & goes to the main menu with no, warning. With streaming services like Netflix or, Hulu, we can always go back to where the show left off but, live shows on Sling, it becomes annoying. Tried updating the system, but to no avail. I will try replacing the hdmi but, I seriously doubt it will work. I'm sleptical about buying a new box because of, this problem happening again. The box is only two years old and this is very disappointing.
tarafından
Why does my ruko tv keep switching to different apps & cutting off & on by it self? Please help
tarafından
Everyone I just talked to someone about this problem, cause I am experiencing the same problem with my tv... The man told me that there should be vents in the back of the tv, try getting a can of air and start spraying the vents in your tv, cause it might be that it is dusty and needs to be cleaned out...
tarafından
My case is really weird. I started to have trouble when I got a new Sony BluRay. Since I plugged it in, the Roku only stays on about 10 minutes and then shuts off. I can only get it to turn back on if I turn on the BluRay! I can’t imagine what’s going on. Should I call Roku tech support? Or Sony?
tarafından
3 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try updating the firmware first:
To do this, go to the home screen and enter the Settings. Under Settings, select System, then System Update, and Check now. If an update is available, apply the update and check to see if it will now work.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I went to try this and it shuts off every single time I try to update. I can’t click any apps or do anything without it just force restarting itself.
tarafından
Yorum Ekle
I read someone's fix to this, it said it could be a conflicting input or remote from for example a fire stick. He said to take out batteries from other remote( the batteries might be low on either remote). It sounded a little ridiculous. But it worked for me. I'm still not sold but it kept me from doing a factory re+boot and then trying to find passwords from three years ago that I have no way of finding.
So take batteries out of other remotes connected to your TV. And remember to always pray to Satan he can kick Jesus'
Puan 2
4 Yorum:
Thank you scottcboth I got mines working after pulling my batteries out of my firestick. This is a great fix
tarafından
Wow.. Can't believe it works for me too.. My roku TV was shutting down every time I tried to change inputs or load Roku Live TV.. Removed the batteries from my Nivieda Shield remote and doesn't shut off the tv now.. Thanks
tarafından
Didn’t work and your dead wrong about Jesus!
tarafından
Did not work for me. TV keeps shutting off if I am on Newsmax channel.
tarafından
Yorum Ekle
Try a different HDMI cable. It could be a bad HDMI cable.
Roku 3 kepps shutting off for no reason
If that does not work, call Roku support as they are available 24/7.
Puan 0
1 Yorum:
@rleematt I would contact Roku Support about this matter then. I don't know anything else that could be awry.
tarafından
Yorum Ekle
After scouring the internet for possible solutions for the on/off switching problem, I found the one that worked for me was simply unplugging the chrome cast cable from my HDMI switch.
Puan 0
1 Yorum:
I have the same issue with my Blu ray,Roku just shuts off,with Blu ray..turn Blu ray back on and I'm where I left off,but only stays on for about 10 min.
I'm lost
tarafından
Yorum Ekle
I had the same issue with roku turning tv off/on. I had some loose cable connections and once I fixed those so far so good but we'll see. Best of luck
Puan 0
Yorum Ekle
Yanıtını ekle
Randall Matthews sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 52,870
