Ana içeriğe geç
Sandwich heater grill - 230 volts - 50 Hz - 2000 Watts
5 Soru Tümünü görüntüle
Repairing Breville TG400 Sandwich Maker
When I insert my toaster to the plug the electricity at my house goes down. I’m sure that it is easy to fix that problem. I opened the toaster and everything looks fine. Maybe the plug itself is the problem? Should I replace it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is blowing the circuit breaker by just being plugged in, I would replace the plug in cable first.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
You might also want to clean some of the dirt on the pins.
Also what else is on the same breaker line you maybe overloading the circuit.
What is the breaker or fuse rating for the outlet you are using.
tarafından
Yorum Ekle
Yanıtını ekle
Eden Bensal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 53
Her zaman: 1,511
