Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Can I Make A Combo Drive An External Disk Drive?
For some reason, my combo drive has become very tight inside my 06 Macbook 1.83GHz. To the point where it won't load a disc by itself. I have to force the disc in and then it can't eject it.
I took it out and tried to make it an external disc drive. (I have a board that plugs into the back and turns it into a USB interface). However, the computer didn't recognize the drive. It still works; accepts discs and all, but it won't mount and it won't recognize keyboard inputs, such as eject.
Anyone dealt with this before or know how to get it to be recognized? I'm running Mac OS X 10.6.7.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Can u see the drive under disk utilities? If you can then try highlighting it and manually mounting it. If it is not seen by disk utility it might be the adapter you are using, it may be faulty or not completely compatible with the drive/Mac.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Man, for whatever reason, that took forever to try out! :) Anyway, it was not recognized by disk utility. I'll check on a new adapter. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
danielahampton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,016
