Ana içeriğe geç
HP Envy TouchSmart Sleekbook RT3290 m6-k022dx; 750 GB sabit disk, 6 GB DDR3 SDRAM ve AMD Elite Dört Çekirdekli işlemciye sahiptir.
How do I replace the battery?
Hi, I need to replace the battery to my HP Envy m6-k022dx (replacement #715050-001). There is an appendage that is attached to the battery, and connects to the computer. I want to know how to remove the appendage without damage. Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think if you are able to just root around a little bit you will be able to find the connector/appendage and then you can disconnect it with a Spudger. Just be careful to not damage it and if it does not come out with the first try keep trying and do not rush it!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
There should be about 12 screws on the bottom of the laptop. Use a PH1 screw driver to remove these screws. Then use a prying tool to remove the back. Once you have the back removed the battery will be right there. Find where the battery plugs into the board and carefully unhook it.
Puan 1
Yorum Ekle
Yanıtını ekle
Fatimah T sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 920
