Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Newest Logic Board Upgrade for my MacBook?
I have an issue with my early 2013 15” and the logic board needs to be replaced. What’s the newest board I can get between 2013-2015 models? I don’t want to have to end up replacing every other part as well. But i’d much rather buy a newer Logic board than pay Apple to replace my current one. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
You will only be able to put a logic board from another MacBook Pro with the same series identifier (in your case MacBookPro10,1), which means you will not be able to put any newer in series wise. You will however be able to put a higher spec logic board within the series, for instance if you have the 2.4 GHz i7 you can place the 2.7 GHz i7 board in for an upgrade, or if you have 8 GB of RAM you could put in a board with 16 GB of RAM (note: it will cost more though). Just make sure it is the SAME identifier as your current MacBook Pro.
I would suggest you by the board from ifixit:
MacBook Pro 15" Retina (Early 2013) 2.4 GHz Logic Board
OR
MacBook Pro 15" Retina (Early 2013) 2.7 GHz Logic Board
Either of these should work. (Going off the info you gave me, double check to be sure.)
But if you want to save a buck, you can search eBay as well, but watch for scams.
Replace a 2.4 GHz Core i7 logic board (motherboard) compatible with the early 2012 MacBook Pro 15" Retina laptop. Includes RAM. Included Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0. Fix processing issues like unexpected shutdowns, reboots, or water damage. Görseli
Ürün
$159.99
Replace a 2.7 GHz Core i7 logic board (motherboard) compatible with the early 2012 MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini DisplayPort), USB 3.0. Fix processing issues like unexpected shutdowns, reboots, or water damage. Görseli
Ürün
$199.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Miles Somerville sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 338
