Ana içeriğe geç
The HP 842c was introduced in 2000. Like most old printers, the cartridges are large and lasted for a long time, and were overengineered. However, it uses a tri-color cartridge which makes it so one color running out ends the entire cartridge.
Why is my printer printing blank pages?
Fix blank page printing ink seems ok. Local print from panel buttons same. Possible circuit board?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it goes through the motions, feeding paper and running the print head back and forth over the paper, the circuit board is almost certainly ok. Why do you think the ink is ok? That seems the most likely cause even if the printer is reporting to your computer that it has plenty of ink.
These older HP printers generally have cartridges with built-in print heads. These have the great advantage that if the nozzles get blocked (as they do with a period of disuse) then you get new nozzles with new cartridges.
Unlikely, but there’s a flexible ribbon which connects the print head to the main circuit board, folded in a “U” to allow the print head to move back and forth. If that had got broken or damaged then it wouldn’t print, though the ribbon is tucked away inside and unlikely to come to harm unless someone was deliberately poking around inside. The other thing to check is the gold contacts on the back of the cartridges, and the corresponding contacts in the cartridge holder, if they had got dirty, perhaps with ink on them, but if that was the problem it’d be surprising if both colour and back were affected in the same way.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
The electric companky changed our meters. My HP Deskjet 8010 Printer was working fine up to that point. Now it keeps kicking out page after page with one line of jibberish printed on each page and won't stop until I turn the printer off.
tarafından
Yorum Ekle
Yanıtını ekle
GCR sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,462
