My right joy-con is not being recognized as connected into the switch.
Hi, I have a problem my switch does not recognize the joy con as connected when i slide it in the switch. The joy con still works but only wirelessly. It does get charged but nothing else. I tried other joy-cons with no luck.
I ordered a new right rail from eBay. I thought the rail might be the problem . I replaced it successfully but no change. If anyone has an idea i would appreciate it.
Bu iyi bir soru mu?
47 Yorum
Hi Sebastian,
Have you by any chance checked the joy-cons or the switch connector pins to see if any are bent or missing? They are located on the bottom of the plastic piece where the joy-con would slide into the rail socket and the bottom of the rail.
Leo tarafından
Ok so I got this problem:
my right joycon won’t connect handheld but will wirelessly and it charges on the switch I’m desperate for solutions but I don’t want to buy a new joycon. Any tips? I already tried what Nintendo said on their support page
Margamez tarafından
Im having the exact problem and dont know what to do
Dreamer WeSoKrazy tarafından
I have a similar problem but with my left joycon, when detached from the console it works wirelessly, but when connected to the console the switch does not detect it being attached so will not work in sync with the right joycon unless it is also detached.
[image|1933833]
Ahsan Amaan tarafından
My joycon just died, stopped connecting or charging, although I've tested the battery with another joy con, and it works. What could be the problem?
naailzahid tarafından
42 tane daha yorum göster
