Ana içeriğe geç
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
PSP go wont turn on when charger plugged in
The PSP turns on and works fine but whenever I plug in the usb charger, the system turns off. The usb side doesnt even have to be plugged into anything, once I jack it into the PSP it will turn off. I set it to USB mode but thing works. The battery still charges though.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Are you talking about a cable? If the other end is not plugged into a USB port and the thing is shutting off, that would suggest the cable you are using may be bad - as in shorted. I would try another cable.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Okay thank you I bought three cables on amazon and apparently one of them worked. I assume yes it was causing the PSP to short.
tarafından
Yorum Ekle
Yanıtını ekle
Alejandro Tellez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 384
