Emergency brake engaged light on the dashboard is always on.
The ABS light on the dashboard never comes on in the few light bulb and system self test seconds after starting the car. ABS scanner shows it can’t communicate with the car’s computer. At the same time, the parking brake On. Warning indicator on the dashboard never goes off. Last night, I noticed a front headlight yellow parking lamp light bulb is burned out. The emergency brakes do operate correctly and all new brakes were replaced recently. The brake shop says the ABS problem is tied to the Emergency brake light always being on. They want $600 to fix both issues. Could a burned out abs indicator light bulb on the dashboard be responsible for no communication with the abs computer? Is the front headlamp bulb I discovered tied to anything else i’ve mentioned. I’ll replace that headlamp bulb later today but still have the abs no com issue and the always on parking brake warning light always on since 2011. Is it possibly my yellow parking headlamp has been burned out since 2011?
Bu iyi bir soru mu?
