Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
MBP Stopped Charging, No Mag Light
Just today, our MacBook Pro (15” Early 2013) stopped charging. I have tried two Apple Magsafe 2 power supplies with the same result. Neither lights up on the power supply connector, and there is no charging indication for the battery in MacOS.
For the last year or so, the battery has reported “Service Soon” or something similar. It doesn’t last long and is probably on it’s last leg.
Is the charging issue related to the battery or is this associated with internal electrical hardware?
Is the logic board responsible for the Magsafe operation and battery charging, or is there another electrical assembly that does this? I’m wondering what should be replaced - logic board, battery, or something else?
Below is an screenshot from coconutBattery.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If the battery tells charging ic that its not safe to get charhed then sequence getting stopped. Try battery replacement first and then if its same thing post your logic board number
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
hello,
do you see green light all the time and won’t turn into red ?
Puan 0
Yorum Ekle
Yanıtını ekle
Jimmy M sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 78
