Ana içeriğe geç
Bu, internete bağlanabilen, fotoğraf çekebilen ve uygulamaları kullanabilen, Tianshi Digi-Lando tarafından üretilen çok yönlü bir tablet olan Insignia Flex 8'dir.
I Forgot my log on pattern
How do you recover your logon pattern? I forgot mine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
insignia tablet forget pattern
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly you will have to factory reset your tablet in order to be able to use this tablet again. Factory resetting your tablet will erase all data stored on your tablet.
Ensure the tablet is connected to the charger and has at least 45% battery left. If the battery dies during this process the device could be damaged.
  1. Power off the tablet fully.
  2. Press and HOLD the Volume + button.
  3. While still holding the Volume + button, press the Power button until the screen illuminates and shows Insignia.  Then release the power button only
  4. Continue holding Volume+ until one of two screens appears
  5.   A) -A screen appears with only an Android mascot in the background. If this happens simply let go of volume + and press it one time.  You should then see the screen shown in item 'B'
         B) - A list of options in the top left of the tablet screen.
Six - Use Volume - to select "wipe data / Factory reset" and press the power button to select it
Seven - Use Volume - to select "Yes -- delete all user data" and press the power button to select it.
Eight - Following the reset, the device should boot up and go through the initial setup process again as when it just came out of the box.
Feel free to ask questions!
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
My laptop reset list is in Chinese which one is the factory wipe/reset
tarafından
this won’t work for me
tarafından
My screen doesn't look like that it all blue with different options and it says I don't have enough space to reset my laptop
tarafından
What do I do if it says there is not enough space to reset the laptop but I can't log in to make space?
tarafından
How do I reset a pin?
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Cindy Snodgrass sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 8,598
