cord does not fit
the part of the cable which should fit in the kindle is not fitting. it seems to be blocked. it is the correct cable
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Alright, so let’s check out the port area and clean it from any obstruction that may be blocking the cable from charging your kindle. Also, could you please upload an image of what the charging port looks like? Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 552
3 Yorum
@einekels Try a different micro USB cable just to be sure it is not the cable, because the cable could just be a little bit deformed.
[deleted] tarafından
@einekels carefully check the cable on either end as well as the board connector. See if you have any bend or broken pins etc.
oldturkey03 tarafından
There is a piece of plastic fixed in the charging port. The paper white kindle is about a yr old but only used on holiday so not been used much this is the first charge for it.
linda.cartlidge tarafından
