SSD upgrade 2018 model
Hello,
Is it possible to upgrade the SSD in the latest MacBook Air (2018) model, or has Apple soldered it making this impossible?
Thanks…
Bu iyi bir soru mu?
Hello,
Thanks…
Bu iyi bir soru mu?
The 2017 model uses the exact same design as the 2015 model. The only difference was an upgraded CPU chip as Intel stopped producing the chip Apple was using.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 13" Early 2015 SSD Replacement and here’s the needed SSD [bağlı ürün eksik veya kapalı: IF123-123]
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 3,739
3 Yorum
There is no 2018 model as of yet. The most current model is the Early 2017 13"
Dan tarafından
Thanks Dan!
From what I understand from the demo below, a 2017 13"'s SSD should be replaceable; do you agree?
Thanks...
Dav tarafından
Yes you can replace it with either the OWC SSD or the custom Apple SSD designed for your system.
Dan tarafından
