Ana içeriğe geç
GoPro Hero5 Black, GoPro tarafından Ekim 2016'da piyasaya sürülen, HD çözünürlüklü ve su geçirmez bir aksiyon kamerasıdır. 4K çözünürlüklü video kamerada sesli kontrol, dokunmatik ekran ve dahili WiFi özellikleri bulunmaktadır.
Sd card isnt recognized
Sd card got stuck in slot and had t be pried out. It now goes In Crooked and isnt recognize. what can be done to repair?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would try opening up the camera and looking at the SD card port on the Motherboard to see if anything is broken.
GoPro Hero5 Black anakart değişimi
If something appears to be broken you can replace the Motherboard with a replacement from iFixit too.
GoPro Hero5 Black Motherboard
This part is the motherboard for the GoPro Hero5 Black action camera. Görseli
Ürün
$24.99
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
So the port is coered obviously by the battery case so hard to see if anyt b ings broken. It does slide in crooked so I asume sometjings crooked or twisted. The mother board has the sd card slot attached so its 1 piece ? Thanks
tarafından
@zchef Yeah, you will probably want to replace the Motherboard as the SD card slot is soldered to it. That’s probably your best option.
tarafından
Yorum Ekle
it is not soldered
it has legs to snap into place
no one sells just the sd card holder,just the motherboard,i looked
but did i overlook one
here is take apart video
https://www.youtube.com/watch?v=Xq3c90Am...
the sucker is glued in places and epoxy applied at lens
once removed front cover is distorted due to heat making some part malleable
because the lens area with epoxy is removed by pulling leaving a rugged rock hard
all terrain surface
it cannot be removed
the rest is screws with torque screwdriver
follow take apart video and pay attention to removing the battery holder
now you will see motherboard and sd card holder to remove mother board and you’ll see
use philips 0 screwdriver to remove mother board
check underside of motherboard for sd card colder mounts
1.you will need to purchase a new front cover that will fit, but not flush due to epoxy residue,
camera is no longer waterproof
when taking apart some screws just spin.had to cut off with dremel and once the board has been removed,pulled the screw fragment out with needle nose plyers
now you don’t have enough screws
but say you bought the overpriced motherboard
the screws are self tapping and others a nuisance
easier to take out
the material the screws are composed of is just sligthly wobbly magnetic
cannot be fully magnetized, say from a discard microwave magnet or buy online
resulting in screw holding lightly to screwdriver,apply even the tiniest pressure the screw falls off.
  1. now you know you should of never attempted to do a self repair
# you can sell off parts
  1. or you should of sold off camera as is saying sd not going in straight and have some other diy take it off you hands
  2. take the hit and but another camera with your parts proceeds or the diy guys money
Puan 0
Yorum Ekle
Yanıtını ekle
Kerry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 842
