Ana içeriğe geç
Suzuki FA50 Moped için onarım ve sorun giderme bilgileri.
30 years without using
Got a Suzuki FA50 30 years ago, put 900 miles on it and storaged. Few days ago took it out got a new battery put some gas but it wont start.
Any idea?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Disassemble and clean the carburetor. Check careful for damaged gaskets and clogged jets. Also see if the engine cranks over cleanly. If in doubt, take it apart and give everything a thorough inspection and cleanout. Missing gakets you can easily make yourself with heavy paper and a 2 stroke engine is rather straightforward to strip and rebuild.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
Works for me. +
tarafından Paylaş
Yorum Ekle
New Plug and possible wiring could become an issue as well. check to make sure that you have spark. Take the plug out and crank it over while holding the plug against the cylinder head. It should give you a spark. Make sure of course that you do not hold it with your bare hands, could be shocking experience. Just got the parts list as well as the complete service manual so do feel free to download it. I do hope you get it fixed and let us know about it. Good Luck
Puan 3
2 Yorum:
has the PARTS LIST been removed?.... its gone. so is service man.
I need those docs.
tarafından Paylaş
radiolabzz, it moved in the last 7 years since this answer was posted. You can find it now right here Suzuki FA50 Moped
tarafından Paylaş
Yorum Ekle
Just same here,30 years old and onused brandnew 1984 FA-50.
Put a bit gas in the tank with 2% oil ,kick two times and he runs as the fire brigade (smoke included).
Gonna do a total check and replace all fluids before i use him.
Ignition switch is missing ,look at ebay ,real rare (price also!).
Gonna look further (cheaper ,anybody knows????)
I'ts a shiny beaty :-)
Puan 1
Yorum Ekle
Yanıtını ekle
Oswaldo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 3,888
