Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
Bu iyi bir soru mu?
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
[deleted] tarafından
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
Nichola tarafından
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
Daniel tarafından
Hi,
Does it do this with the charger connected and switched on?
jayeff tarafından
Not tried that but will do that now and get back. Thanks!
Nichola tarafından
8 tane daha yorum göster
