Right front power window motor replacement
Replace power window motor
Bu iyi bir soru mu?
Hey, Chris. To access your window motor you’ll need to remove the door panel. Here’s a link to a video of someone removing the door panel and window motor of a similar vintage truck. This video is for the driver’s side door, but the steps will be the same for the passenger side other than a different switch assembly. Unfortunately, it’s possible that your window regulator is either welded or riveted in place, and will need to be drilled out. This means you will need to rivet the new one in as well or bolt it in place.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 57
