Ana içeriğe geç
PlayStation 3 Slim, orijinal model numarası CECH-2000 olan PS3 video oyun konsolunun ikinci sürümüdür. Sony Computer Entertainment tarafından üretilmiştir ve orijinal (Fat) Playstation 3'ün birçok sorununu gidermiştir. Ürün 1 Eylül 2009 tarihinde piyasaya sürülmüştür.
465 Soru Tümünü görüntüle
Any way of removing the Blue Screw of Death on a PS3 Slim?
I have a PS3 Slim in which I was going to replace the hard drive on, however the blue screw to get to the hard drive enclosure is so incredibly tight that even with the most amount of force I can muster, I cannot, for the life of me, turn this screw even a bit. Any suggestions?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try putting a towel with a lot of grip in between your hand and the screwdriver, hopefully the towel will increase traction between you and your hand. If your driver keeps slipping on the screw, stop trying to loosen it because you will strip the screw. Find a place that has the proper screwdriver for the job and take it there.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you, I will try this as soon as I get home. Would using a pair of pliers around the screw be useful, or should I avoid doing that?
tarafından
@solbady If the acrew is made out of zinc definitely do not do that but if it is steel then that might work.
tarafından
Yorum Ekle
En Yararlı Yanıt
I would take it into a hardware store and make sure you have the correct bit. You might need an impact driver or just more brute force.
Puan 1
1 Yorum:
I will definitely do this if the paper towel solution doesn't work.
tarafından
Yorum Ekle
Yanıtını ekle
Jordan Schivek sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,735
