Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Device won't power on
Device would not power on.. I replaced battery, charging port & screen. It still will not power on.
Bu iyi bir soru mu?
Puan 1
1 Yorum
All I know is its 4 years old and it was thrown across the room by kids.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Do you have any insight as why the phone died; drop, previous repair attempt…water? That would give us a clue as to where you start.
Try booting just the board, known-good battery and Lightning port. Then connect it to an iTunes enabled computer. If it is recognized, then some peripheral is causing issues. If it isn’t, then you likely have a logic board issue. You could start probing the board by looking at the main voltage rails (PP_BATT_VCC, PP_VCC_MAIN and PP5V0_USB). If you’re not comfortable with that, have it looked at by a micro-solderer.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
how to just boot the board
tarafından
Yorum Ekle
Yanıtını ekle
chrisellis87 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 49
