Ana içeriğe geç
TI-Nspire CX el hesap makinesi; tam renkli, arkadan aydınlatmalı bir ekrana, ince ve şık bir tasarıma sahiptir ve TI-Nspire şarj edilebilir pil içerir.
Nothing showing on the screen?
Hi! I have a TI-Nspire CX calculator, and now my calculator can’t turn on the screen. It’s broken maybe is because I am trying to upgrade the calculator to a TI-Nspire CX  CAS calculator.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
You cannot simply flash the CX CAS firmware to the CX calculator so you may have bricked the calculator. If you haven't already tried: unscrew the battery cover and remove the battery; while the battery is the removed press and hold the reset button down (using a pen, paperclip, etc.) for around 10 seconds. Put the battery back in and let us know if it works!
tarafından
tarafından
Honestly I'm not much help with Nspire calculators. @a16457m I suggest you turn your comment into an answer!
tarafından
Will do @TheLastMillennial
tarafından
Lol I flashed my nspire with the cas os
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I was having trouble with a CX nspire. The startup sequence would run and then the calculator would go into a dark grey screen that seemed to have moving lines. I reset several times, no success.
What fixed it was the following. I switched out a battery from a good calculator. With the good battery, the computer was able to restart and run normally. When I put the old battery back in, the calculator also ran normally. (while connected to power on the usb cable)
I am going to let in charge for a while and see if the fix is permanent. I may have to buy a new battery but at least it is working now.
Puan 0
Yorum Ekle
Yanıtını ekle
Wenqian Li sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 2,621
