Ana içeriğe geç
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
306 Soru Tümünü görüntüle
My Xbox 360 Wi-Fi Has problems troubleshooted already
Connects to wifi okay but then dosen’t do anything with it. Like it says connected but nothung that requires wifi works. Same problem with Ethernet. Please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hmm. Try manual wifi settings, look into it, and make sure everything seems right. Other than that, best I could tell you is to replace the motherboard for it as it doesn’t work with Ethernet either OR just fresh install the system.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
How do I fresh install the system?
tarafından
Erase Xbox 360 Data
Under Device Options select Format and verify you want to remove all content.
After that, you'll be asked to restart the console.
That's it! ...
After that you will need to sign in or set up your Xbox Live account and configure everything how you want it.
This will delete all your games but may fix your internet problem.
tarafından
I just added a picture of it the memory has issues as well
tarafından
@ja89028
I'm kind of confused pal.
The picture shows your internet connection is completely fine. You just need to pay for Xbox Live.
Am I missing something?
tarafından
Yorum Ekle
Hello,
You need to check you internet connection & talk you internet provider.
Puan -1
Yorum Ekle
Yanıtını ekle
Reece Raaum sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 199
