Ana içeriğe geç
Repair guides and support for a wide range of clocks.
18 Soru Tümünü görüntüle
Display Screen Electrical Connections
Attached is a picture of the display screen for a Brookstone clock. A ribbon cable was attached to the black pads shown in the picture apparently by either electrical conducting glue or something in the ribbon cable covering works as glue when heated? The second part of the question is I see not electrical leads from the pads into the screen. How does such a system work?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Look at it vary carefully with the light at different angles and you should see very faint almost completely transparent conducting tracks. There’s a picture of a calculator display showing the tracks at https://wiki.restarters.net/Connectors#E...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Carroll Stroh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 121
