Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Stuck on DFU mode error 4014
Hello all this is my first question on this forum so sorry if i might sound stupid
sometime ago i bought a iphone 6 that suffered a hard fall (surprisingly only the lcd was broken not the glass) i recently replaced the screen. but the device itself is stuck in DFU Mode so far i tried to restore the device on Itunes and 3utools with always the error 4014 on itunes. I quess i the logic board might be damaged do any of u guys have a idea on what i can do? Thnx
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This will definitely be board level from what you have explain.
Error 4014 could indicate a couple factors like nand baseband and tristar.
The board will need to be assessed and most likely need micro soldering work to be repaired.
There will be a iTunes error log that you can look at although if you're not in the industry may be hard to get your head around.
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Victor99 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 537
