Ana içeriğe geç
Canon Powershot A590 IS, 4x optik zoom ve 2,5 inç LCD ekrana sahip 8 megapiksel dijital bir kompakt fotoğraf makinesidir.
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
lens do not get back when on/off button is pressed.
Puan 2
1 Yorum:
same answer as above :-)
tarafından
Yorum Ekle
make sure you are not holding the lens when you turn the camera on.
Puan 1
Yorum Ekle
can you help for restart the camera
Puan 1
1 Yorum:
Camera lens does not move when switch.
tarafından
Yorum Ekle
Yanıtını ekle
Pinky Kasotia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 6,660
