Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Touch Screen not Working After Replacement
Hi ,
I’ve recently went to replace my 5s’ cracked screen to a new on only to discover that the touch on the new screen was completely unresponsive. Thinking I had a dud screen, I sent it back and got a refund.
I tested my original screen with my phone again and the touch worked fine.
Ordering a new screen again, I went to install it today and again the touch is completely unresponsive! The new screen is an original apple screen so I doubt it is faulty the second time, however I doubt my phone is faulty due to it working fine with the cracked screen.
Honestly any help on this would be appreciated, because im stumped.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The only thing I can think of is that you may have caused pry damage or long screw damage.
Did you put the screws back in the exact same location if not then that could cause long screw damage and prevent touch.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Make sure all your ribbon cables are properly seated. Ive had similar problems with iphones not working and the problem simply was a bad connection.
Puan 0
Yorum Ekle
Yanıtını ekle
kmes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 56
