Ana içeriğe geç
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
24 Soru Tümünü görüntüle
Model PSX3 tire inflator won't turn on, other functions have power
PowerStation model PSX3 has both tire inflator and jump starter functions. It also has a work light. The inflator had been working fine, but now the push button switch has no effect. Seems as if an electrical connection has been broken. The work light functions perfectly, so there is power available. Inspection of the interior wiring didn’t reveal anything obvious.
Bu iyi bir soru mu?
Puan 0
1 Yorum
my PSX3 compressor has started to run very slowly put-put-put...can that be fixed?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
david barkman  it sounds like a bad switch (mechanical failure). If you can disassemble it, check the switch and you could always try to replace it. We would need to see what it all looks like in order to give you more details. You can always post some pictures so that we can possibly provide you with a more precise answer. Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Everything works on mine except it doesn’t seem to charge. Light works and compressor works .
Have stripped it down and found a capacitor and resistor burnt out. Can see the capacitor values but there is no way of reading the resistor value. Any idea where I could get a circuit diagram please?
Thanks
tarafından
Yorum Ekle
Yanıtını ekle
david barkman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,680
