Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Replaced lightning port, but no sound from headphones
I replaced my lightning connector yesterday with new part; everything seems to work except for the headphone jack. The phone recognizes that there’s a headphone plugged in, and the controls work, but no sound comes out.
Even the mic works, so not sure if it’s a bad part or if there’s a bad connections somewhere; any help would be greatly appreciated!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Solved; ended up being just a defective part; replaced with new component and everything works!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Make sure connection on board side is getting full contacts it will only take 1pin to stop headphones from working.
If after you are encountering the same problem i would swap back your old port temporarily not need to remove full flex just click it in and test headphones.
This will allow you to determine if you have a faulty item.
Puan 2
2 Yorum:
Tried old connector as recommended. The old one works, but the new part doesn't. I'll request a replacement part from ifixit parts shop. Thanks!
tarafından
That's great glad to see you worked it out
tarafından
Yorum Ekle
Maybe check if you soldered it in right,you may of messed up and this is why it does not work.
Puan 1
Yorum Ekle
Count the rings on the headphone plug, 3 rings? 4 rings? try different ‘rings’ headphones.
Puan 0
Yorum Ekle
Yanıtını ekle
Jake L sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 175
