Ana içeriğe geç
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Why is my Mac screen doing this?
Having some issues with a grey vertical line intermittently on the screen. When I touch around the actual screen it seems to make the problem occur more. When I leave it upright and open on a flat surface sometimes it will go away.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sadly you banged your systems lid or stat something heavy on it damaging the LCD panels connections to the ribbon cable. We call this failure a TAB error. When the fragile vaporized metal on the LCD glass has pulled away breaking the connections.
To fix this you’ll need to replace the display assembly following this guide: MacBook Air 13" Mid 2011 Display Assembly Replacement and here’s the needed part: MacBook Air 13" (Late 2010-Mid 2011) Display Assembly
Replace a display compatible with the model A1369 Late 2010 to Mid 2011 13" MacBook Air laptop. Part #661-5732, 661-6056. Features a 1440 x 900 13.3" LCD screen. Görseli
Ürün
$399.99
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Ouch! That's gonna be expensive...
tarafından
As a cheaper alternative can I just replace the LCD panel instead of the entire display?
tarafından
Sorry, it's not really cheaper ;-{
The problem is you'll need to replace quite a few pieces as you'll damage them in the process.
You'll also need quite a few tools and even afterwards it won't be as neat as the edges will be nicked up and you'll likely have some damaged backlight sheets.
To give you an idea how messy this can be take a look at this guide: MacBook Pro Retina Display Teardown
I'll do the older MacBook Unibody LCD's, I won't do the Air's or the newer Retina's.
tarafından
Yorum Ekle
Yanıtını ekle
Matthew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 372
