Ana içeriğe geç
Mart 2017'de piyasaya sürülen G6, LG'nin Android 7.0 işletim sistemiyle çalışan amiral gemisi telefonudur. Bu cihaz, tüm büyük kablosuz operatörlerde mevcuttur. Cihazın fiziksel olarak onarılması, su geçirmezlik özelliğini ortadan kaldırabilir ve cihazı sıvı temasına karşı savunmasız hale getirebilir.
Touch screen not working
I have a phone labeled “LG Fortune 2”, I chose “G6” because appearance-wise it was the closest, “Fortune 2” not being in the list of devices.
It got wet though not soaked - rained on , predictably would not boot. The moisture telltales all turned orange.
I dried it out and it booted fine, screen lights normally, but the touch screen will not work at all. The only way to get it to light is the home button.
What, if anything, can be done to correct this?
Thanks.
Bu iyi bir soru mu?
Puan 1
1 Yorum
Thanks. I will replace the digitizer. I see they can be had for about $10.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you need a front digitizer replacement. If that isn’t the issue, it could potentially be a logic board short. Water damage is tricky to diagnose directly, but I would try a digitizer replacement first.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
As Jonathan said, water damage is tricky to diagnose. There may be corrosion on the screen connector causing the touch not to work. Its also possible a component on the board is shorted out. You will have to replace the whole screen assembly (glass, digitizer, LCD) if you want a new touchscreen because it is bonded together. A new screen will do nothing though if the corrosion isnt cleaned off of the connector, or if the logic board is shorted. Its going to be about the same or cheaper to replace that phone than fix the screen.
Puan 0
Yorum Ekle
Yanıtını ekle
Andrew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,176
