Trackpad not clicking after some use
The trackpad on my MacBook Pro (13”, 2017, No Touchbar) refuses to register clicks after 30 mins - 1 hour of use. Sometimes I have to press really hard for it to register, and often, as I hold (not press) my finger on the trackpad, it registers as constant clicking.
The MacBook had water spilt on it and the top case was replaced.
Bu iyi bir soru mu?
4 Yorum
a mi me pasa lo mismo ya lo he probado todo lo ultimo reinstalar el ma os y nada la unica forma que hay de que me vuelva a funcionar es la de dejar el mac apagado durante unos minutos, entonces funciona unos miutos y va perdiendo el click poco a poco hasta que deja funcionar la solucion tambien seria remplazar el trackpad?
The same thing happens to me, I have already tried everything last, reinstall the maos and nothing, the only way to make it work again is to leave the mac off for a few minutes, then it works a few minutes and it loses the click little by little until it stops working, would the solution also be to replace the trackpad?
Oriol Tinez tarafından
@Oriol Tinez - Lo siento, sí, también necesitas una nueva unidad de trackpad.
Sorry yes, you also need a new trackpad unit
Dan tarafından
okey gracias, pero es original no? porque ya compre un trackpad de otro fabricante olive me parece y me dejo de funcionar hasta el teclado conectandolo y no funcionava el trackpad tuve que volver a poner el antiguo
OK, thanks, but it's original isn't it? Because I already bought a trackpad from another manufacturer Olive I think and it stopped working until the keyboard connecting it and the trackpad did not work I had to put the old one back
@Oriol Tinez - Lamentablemente, debe utilizar la parte correcta de Apple [bağlı ürün eksik veya kapalı: IF123-057-3]
Sadly, you need to use the correct Apple part [bağlı ürün eksik veya kapalı: IF123-057-3]
Dan tarafından
