Is spraying conformal coating a good idea for a MacBook logic board?
A common cause for Macbooks to die is corrosion on the motherboard in certain areas. It is incredibly easy for MacBook logic boards to get corroded by just humidity in a room. So I had an idea that maybe I could spray my entire MacBook Pro 2015 (top tier model) logic board with conformal coating.
If I was to spray the board on my $3000 laptop, does anyone have any tips as to what I should watch out for? Is this not a good idea? This is a first for me. I want to make sure I don’t have to learn the hard way what not to do.
Bu iyi bir soru mu?
1 Yorum
For future world my answer. Apologies to necro an old question.
Even basic house dust drawn into a computer can cause issues with corrosion, the build up is likely to adsorb moisture from air also drawn into the computer from the cooling system.
Even 'dry' rooms are not actually dry, and humans exhale moisture laden air onto and around their devices constantly.
Instead of completely covering the circuit board/s of a computer with an industrial conformal coat, it would be best, imo to ascertain the components or area of the logic board in question that is most likely though experience or asking on repair media channels to become damaged through corrosion, then carefully sealing those areas leaving the 'less at risk' parts uncovered.
Watching mac repair video channels you will see that corrosion is often present on logic board component's solder joints, even if there is no actual liquid damage, all from dust and normal humidity.
Martin Rabson tarafından
