Ana içeriğe geç
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
How to replace drive belt
I have a 2002 Murray 11 HP 30” riding mower, model 31602A. The drive belt is frayed and slipping. I have a replacement belt, but cannot see how the belt can be installed. I removed the cutting deck and can loop the new belt over the blade pulley and onto the drive pulley, and feed the belt over all linkage, but cannot see how to install onto the rear pulley. Any suggestions would be appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There should be an adjustable pulley. Or a tensioner pulley. It will have a square hole in the middle for a ratchet to insert and move it enough for you to loosen the tension on the belt and finish installing
Update (11/03/2018)
I know you have a different model then what the video is but I hope it helps
https://youtu.be/u1o9WQqOSvw
https://youtu.be/HKI7qI7iIBE
https://youtu.be/dW8DYMCjC9E
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for the response, but the idler is not a problem. The shift lever connects to a shaft that goes into the gear box in front of the rear drive pulley. I don't see how to get around this.
tarafından
Bring it to the shop
tarafından
Yorum Ekle
Yanıtını ekle
Misco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 53
Her zaman: 8,176
