Ana içeriğe geç
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Soru Tümünü görüntüle
Is there a guide for replacing iPad Pro 12.9" battery?
ive used the iphone 6 plus battery replacement guide and replaced the battery on my phone a few times.
I had a first generation ipad pro 12.9inch, and im interested in replacing the battery for it, but when i did a search, i didn’t see any guides for ipad pro battery replacement.
I know there are tear downs and also guide for replacing the ipad pro screens, home buttons etc.
Does anyone know of a good guide i could watch that walks me through how i could replace the battery on my ipad pro 12.9 inch? I was wondering if the reason there isn’t one for the ipad pro is because the technique is similar to standard ipad battery replacement?
Thanks in advance for any help :)
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sorry no guide, but you really don’t need one! The teardown guide will give you enough info to figure things out iPad Pro 12.9" Teardown. Here’s the needed steps:
Step5 & 6 - Removing the display
Step9 - Remove plate, disconnect iSight camera from logic board.
Step10 - Remove shield
Step11 - Just disconnect ribbon cable from logic board
Step12 - Just disconnect speakers form logic board
Step14 - Disconnect antenna cables from logic board and carefully lift them past the edge of the batteries and the remove the two clips
Step15 - Disconnect the other two speakers and the last ribbon cable to the switches, then lift the logic board up and out.
Step18 - Carefully heat the backside of the case to soften the pull tapes adhesive using a hair dryer or heat gun on low. Using a pair of forceps like this one: Debakey Lung Forceps as they allow you to pull the tapes more effectively as you don’t want to tear them as you pull.
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
what @danj says.
tarafından
Thanks so much!! :)
tarafından
Yorum Ekle
Yanıtını ekle
thuaners sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 7,774
