Ana içeriğe geç
A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
Switch on my tablet needs replacing
My on switch on my note pro is faulty . How can i replace it without loosing my photos and data downloads ?
the tablet is going perfect,but the switch seems to be broken or just worn ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Joe,
I would advise that you backup your device before making any repair effort.
  1. From a Home screen, navigate: Apps icon  > Settings > Back up and reset.
  2. Tap Back up my data to enable or disable.
 Enabled when a check mark is present.
 If disabled, existing backups are deleted from Google's servers.
  1. From the Backup account field, ensure the appropriate account is listed.
 Back up my data must be enabled.
  1. To change accounts, tap Backup account.
    1. Tap the preferred account
  2. Tap Automatic restore to enable or disable.
This will ensure you don’t lose any data.
As far as replacing the switch, this is the part you will need:
[bağlı ürün eksik veya kapalı: IF331-000]
The volume button board contains the board for the power button as well. You won’t nee to replace the physical button you see on the outside, the problem would be in the circuitry beneath.
HOWEVER, you did not include your device model information. Please ensure this part is compatible with your device.
Thanks
Ryker
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
JOSEPH H CRAIG sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 248
