Ana içeriğe geç
Moto G6 Play replacement screen 1mm too short
I know this is going to sound weird but I ordered a screen from 2 different suppliers for a Moto G6 Play and both replacement screens are 1mm too short. Everything lines up at the top and the shape is perfect but there is a gap at the bottom. The flex cables work and are a perfect match to the original. Anybody else have this issue?
Bu iyi bir soru mu?
Puan 6
3 Yorum
Yes got the same problem, I recommend buying with frame assembly
tarafından
Our shops have ran into this issue as well. We now buy it with the frame only.
tarafından
Unable to find XT1922-9 replacement lcd w/ frame...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Jestin, I have since discovered there are 7 variations of the G6 Play. Some of them use a 150mm screen and some use a 152mm screen.
If the supplier doesn't specify, you will most likely get a 150mm.
I found an eBay seller that lets you pick which one you want and it worked great.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
I had the same issue today with the screen i received from a local supplier today. Everything works on it, its just short.
I end up replacing the screen anyway.
tarafından
Yorum Ekle
iFixit sells genuine Motrola parts. I would sugget you search on iFixit for availability of the specific moto part you need in order to ensure a proper fit. The genuine parts are going to be a lot more reliable!
Puan 0
Yorum Ekle
Yanıtını ekle
brentongraber sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,224
